Hi all :]
Question 1)
Is it worth upgrading to windows 7?
I ask because ive heard windows 7 32-bit can use 4 gig of ram straight out the box.
is this possible?
if i did upgrade would it show 4 gig? or 3.5 gig (my 4 gig of ram MINUS my 512mb of GPU ram)?
and if money was no object is it worth upgrading for an extra gig/half a gig of ram?
Question 2)
Also, is there anyway that you can deactivate and re-activate your GPU easily?
So that the ram from your GPU does not get deducted from your currently installed ram.
Thanks!
current set up -
windows xp 32 bit (i have a 32 bit cpu)
4 gig ram installed (2x2gb)
512mb gpu - Geforce Go 7900 GTX
This only shows 3 gig of visible, useable ram.
Question 1)
is this possible?
Question 2)
Thanks!
