Hi, just a quick question regarding running 32 bit software on 64 bit vista home premium... I've had a quick (not thorough) look on these forums and using google, and can't find any explanation for this program failing to install unless it has 16 bit drivers or something... Anyway, I was just wondering is there a way to get around this problem and use this software on my 64 bit OS.... or If there is no hope and I just wasted my keystrokes.
It is a CAD program that school let you have, but the problem is I'm meant to be using it to draw some of my products on it, and If I can't use it at home I have to do it at school.... which would be a real pain in the ...neck.
I was stuck with just ProDesktop for 5 years at mine ;_; )
