32” Monitors with remote controls?
17 May 2020
So ive got a king size bed at home where the tv comes out at the end of it and the max it can take is a 32” and i cant find any 4k 32inch tvs as they dont make them and i know i know its not worth it apparently but i beg to differ when im so close to the tv i can plus i have a virgin uhd tivo box that i wouldnt mind watching the football on when i lay in bed in the mornings.
(The bed has built in surround sound with a optic output on it)
So my idea was to get a 4k 32inch monitor and attach a vesa extension mount to it so it fits my bracket attached to the bed but my only real problem is a controller to turn it off!!! Now ive seen a couple monitors with them but they’re 27inch which is no use to me, so if anyone knows of any monitors that match my needs or knows how to connect controls to monitors id really appreciate the help!
Would a smartplug solve your problem since it's only on / off control you want?
I must admit my monitor is powered 24/7 it just goes into standby if there is no signal.
