- 6 Feb 2008
Hello,
Looking at getting a new monitor and a little bit lost in the monitor jungle and really unsure what to get.
In terms of use:
- Due to now WFH it will be used heavily for work (multiple excel, word and PDF docs)
- As it will be in spare room I want to also use it to watch films & sport when my partner is using the main TV
- I am currently deciding whether to get an Xbox X or a PC (If I go down the PC route I think my budget will only stretch to a 3060 TI) so it will be used to play games.
Budget:
Ideally I would like to only spend between £350 - £500. However, I am keen to get a decent screen that will last me some time so if there is a significant benefit to be had I could stretch the budget to £800 and save elsewhere.
Screen Size:
I must admin this is the area I am really struggling to nail down... I am keep looking at 27", 32" and 34" widescreen.
I was pretty set on getting a 27" screen but thought this will quickly feel small and possibly frustrating to watch films and play games on. My current desk is 120cm x 60cm so I think a 32" / 34" will be okay and is the right option in terms of what I want to use if for and not causing neck issues due to size. Welcome your thoughts and suggestion and happy to reconsider 27" screen if that is a better option.
Possible Screens I am considering:
34"
LG 34GN850 @ £798 (is it really worth the extra?)
AOC CU34G2X @£459
LG 34GL750-B @£348
32"
LG 32GP850 @ £448
LG 32GN600 @ £248
Thanks
In terms of use:
Budget:
Screen Size:
34"
AOC CU34G2X @£459
LG 34GL750-B @£348
32"
LG 32GP850 @ £448
LG 32GN600 @ £248
Thanks
