- 24 Jul 2006
- Hoddesdon, London, UK
Anyone know what the part no. is? or where i can get a set? Its the steel clip that holds the c pillar trim to the car. I was looking for the antenna amplifier to check if the connectors were loose because its getting a fair bit of interference from the window defroster. Managed to lose 2 clips out of 4 as they fell behind and my seats don't go foward. Currently have 3m double sided stickies along with one clip and screw on each side, which seems to be doing a fine job anyhow, so its not necessary just like to get it right.
Its an E90 320D SE 06 reg.
Cheers
Didn't find the conector box btw. no idea where the hell it is as my antenna supposed to be in the rear screen
Cheers
