I made a post about this one before, it wouldn't start at all, hooked up some jump leads and it started right away, and never caused a problem since.
Anyway, last week it started to not start first time. I didn't even bother to try it myself, just fitted a new battery given what happened before.
The problem is still there though. First time you turn the key it will crank for as long as you care to hold the key and will not fire. Turn it off and try again and it will start straight away, once started there are no running problems at all, and it will start fine until its left to go cold again.
Ideas welcome!
Ideas welcome!
