- 6 Dec 2005
hi all. I need some advice as to the following see my sig. Fear is probably the most taxing game i play atm which I want to play in 1680x1050 resolution.
I have enough cash saved to go for a 8800GTS 640MB card OR the 320MB card and another ballistix matched kit to double the ram to 4x 512Mb sticks total (as pairs cost about 70 quid delivered).
So its a question of whether the increased memory on the card at this resolution hopefully covering the 'gaming overhead'. Im leaning towards getting the 640mb card and using it in any bigger upgrade later (hopefully much later
) which will no doubt require ddr2 instead. Any thoughts?
thanks in advance
) which will no doubt require ddr2 instead. Any thoughts?thanks in advance
