32bit & 64bit vista and 1 confused noob
11 Aug 2006
Essex
I'm a bit of a noob when it comes to 32bit and 64bit o/s's, is 64bit backwards compatible with 32bit applications?
in short, is it worth getting 64bit over the 32bit version?
thanks for any replies
As Bloodwolf pointed out you can run 32bit apps. The only issue I see on a 64bit OS is drivers. Now this wont be a problem with your 'bigger' brands such as Nvidia, ATI and creative, but may be a problem with devices such as mobile phones. My friend was unable to connect his K750 on Windows 64 and has not found a solution to this day. I'm assuming Vista 64 bit will require seperate drivers as the previous 64bit windows did.
Edit.
A current issue for gamers is the Copy protective software that some games are using. eg.. fahrenheit will not run on 64 due to this.
Vista x64 runs all your x86 applications at full speed.
The only difference is that it needs 64 bit drivers.
thanks lads
just one more thing i want to know that will defo work is flight sim x? anyone know if it has any trouble running on vista 64bit?
cheers
cheers, thanks very much ;)
one last thing. i have 2gb of ram, will that be enough for vista 64bit?
