Ok ive been planning a new build for a while and want to get everything spot on, have had various other questions that have now been resolved but would like some input on one last query.
Im unsure which OS to use for my new system. I have access to 32bit XP, 64bit XP and 64bit Vista (my dad gets free copies/licences from work
I have this problem as i will be buying 4gb of RAM and would like to see it all used, however i would also like to see no compatibility probs and get the best gaming performance.
Currently im thinking of going with good ol' 32bit XP as Vista seems to perform significantly worse in games. My gfx card will be 512mb so i should see a little under 3.5gb shouldn't i?
As for 64bit XP, i like the sound of it on paper, full 4gb support but ive heard its plagued with compatibility issues and would the extra half a gig or so prove 64bit to be worth it?
64bit Vista on the other hand, does it suffer from the same compat issues as XP? Still a bit resource hungry for my liking, enough to see frame drops in games compared to XP, so would this in effect cancel out the performance of the extra ram??
What would you go for? Thanks again guys.
)I have this problem as i will be buying 4gb of RAM and would like to see it all used, however i would also like to see no compatibility probs and get the best gaming performance.
