32bit drivers on a 64bit machine?
26 Aug 2004
United Kingdom
Hi
I have an Intel Core Duo PC with vista 64bit buisness edition installed and have a hercules dj console which only has 32bit drivers.
Is there anyway i can run these drivers on this pc?, would virtual pc be an option?
Thanks in advance
As far as I know a Virtual Machine would be an option, HOWEVER I believe you will require to purchase another VISTA LICENCE, unless there is something that overrides this because it is the same machine. Might want to check with others here...
this is not what virtual machines are for
either hope that they release 64bit drivers on their site, or change card, or change to 32bit
