Gathering its 64Bit, if you are asking whether to go XP or Vista, then Go for Vista.
Its getting better everyday.
My own choice however is XP64 as its faster in every test I have done bar a small few.
You can use it all, but you will gain nothing from it compared to 32bit Windows. To make use of 64bit you need more than 4gig.
Apps on 64bit OS's use much more memory than on 32bit so all the space you just gained by moving to 64bit you just lost again because the higher memory allocation of a 64 byte.
go for 64 if you install 4GB also remember firstly install 2GB and then install Vista and then once you done and download MS patch fix for support over 3GB >> http://support.microsoft.com/kb/929777 and then install up to 4GB in total.
Hello NinjaPaul, Windows Vista 64-bit without a shadow of a doubt. Unless you specifically know that the programs that you use will have problems then there is really no reason to even contemplate weather to go for either 32-bit or 64-bit.
Now, regardless of the amount of physical memory that you have, providing it's more than 1GB, though I'll suspect that the majority people on these forums have at least 2GB of RAM anyway, 64-bit is just a much better platform all together, it is securer, more stable and generally faster and not to mention the memory capabilities.
