32gb RAM FOR 5800X
21 Jan 2017
County Durham
Hey, I'm looking to upgrade from 16 to 32gb, currently using Corsair LPX ram as I need the lower hight due to radiator and fan clearance.
I'm a little out the loop these days but what would be the go to LPX 32gb kit, speed? CL?
Any good kit with speeds of 3200 MT/s to 3600 MT/s will be fine.
I'd suggest going for 3600 MT/s speed RAM as then the Infinity Fabric and RAM will be in a 1:1 mode out of the box.
Something like the Patriot Viper Steel DDR4 32GB (2 x 16GB) 3600MHz Kit - PVS432G360C8K will be great.
Don't overspend on DDR4 RAM, it's cheap and most good kits are fast enough.
What is the spec of your RAM?
If i remember correctly, nearly all modules up to 8GB are single rank so you probably are ok to just add to what you have now.
I did used to run 4 sticks of single rank with a 5800X and had no problems at all.
When DDR4 was new, you could buy dual rank 8GB sticks, but they're probably only slow ones (like 2133-2666). The ones I have are all 2133.
Nowadays, they (* some) don't even have 8 memory chips :o
The ones i had was 3600Mhz and could not find any dual rank. I only swapped them out as i did not want RGB any more.
Even when i got the 2 x 16GB kit there was reports that most are single rank, i got lucky though and got dual.
