The online reviews for the LG 32GK850F all report no issues with g-sync enabled.
Newer Freesync 2 monitors should all work fine as the spec is tighter, more defined.
It's the older freesync monitors that you need to watch out for and test first as they could have problems with flickering and blanking out with g-sync enabled.
FreeSync (G-Sync Compatible) is just a Nvidia certification thing.
Just means those monitors listed have been tested, meet their requirements and definitely work.
But it does not mean that a monitor that is not listed will not work.
