my spec up there will most likely not play those games at a very high res smoothly when full aa and af or the ati equivilents are on max. it however should help provide a base for you to put better hardware in as time passes.
Antec NSK 4480B Mini Tower Case (Black) - 380W Earth Watts PSU £39.99
(£46.99)
PowerColor ATI Radeon X1950 Pro AC2 SILENT 256MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail £64.99
(£76.36)
Sub Total : £270.93
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £10.95
VAT is being charged at 17.5% VAT : £49.33
Total : £331.21
Bigger hard drive, better cpu and a faster dvdrw for less. If you need an OS as well then you will have to find an extra £57. That power supply should be fine with that lot as they are quite decent psu's. Good cases too. I have a couple of those dvdrw drives and they are very good. That mobo is an excellent budget overclocker too and should easily get that E2180 past 3GHZ. You may need to buy a decent cooler for that though.
