That lens makes a very effective macro lens if you take off the front element instead of splashing out £300 for a real macro lens. It's a bit of hassle but the results can be outstanding
i found that reversing the lens is much better than removing the front element, i will provide evidence of this tomorrow as i have now tried both techniques, my favourite reversed 35-80mm photo is .......
Basically, get your lens, and instead of mounting it normally onto your camera, hold it onto the body so that the front lens is looking inside the camera body.
I'll try and sort a photo out, but here's another example of how good the reversed lens is.....
here is a resized image i took last year of a very tame dragonfly
now, here is a 100% crop of the full size image......
Found this much easier to use, just turn the lens around and hold it against the camera body.....
Pros;
Easy to do
Lens is kept complete
Cons;
Allows the camra internals to be exposed to elements etc.
Anyway, heres a couple taken handheld very quickly;
100% Crop;
Please remeber this is handheld and very quickly done......
These required the flash to be used and as can be seen, ocassionally the flash is shielded by the lens but overall, I am very impressed by this technique.
