- 15 Sep 2006
- Azeroth
yes, its yet another one of these posts
In a couple of days time i'm going to get a new monitor (to replace my ageing 21" crt)and i have narrowed my choices down to either a
NEC MultiSync® LCD20WGX2 20.1" Widescreen LCD Monitor - Black/Silver (MO-009-NE)
or
Dell Ultrasharp 2007WFP 20" Widescreen LCD Monitor - Midnight Grey (MO-011-DE)
after having spent the last 2 hours reading posts here i'm now more confused than i was, I do play lots of games but its mostly just WOW nowadays
and it would be nice to be able to plug my XBox 360 into it as well (can you have the computer plugged in through DVI and the Xbox through VGA at the same time? and how do you switch between the 2?)
I'm starting to wish i hadnt read as many posts on here because before i had almost settled on the dell...
any comments would be very much appreciated before i spend this much on a monitor
also the NEC is out of stock, any idea when it'll be in? as im quite impatient and knowing me i'll just order whichever is in stock at the time
Thanks again
or
and it would be nice to be able to plug my XBox 360 into it as well (can you have the computer plugged in through DVI and the Xbox through VGA at the same time? and how do you switch between the 2?) I'm starting to wish i hadnt read as many posts on here because before i had almost settled on the dell...
Thanks again
