3540 3DMarks 06 look right with my spec?
Score seems right
I have virtually the same spec (apart from the cpu overclock) and get 3350-3450 in 3D Mark 06. I've found that the real average with our spec varies from 2500-3500! :)
Check the 3D06 thread and compare it.
Sunlitsix, yours seems a bit low as 3D06 is multicore threaded and as yours is clocked to FX60 speeds i would have thought you would be higher than that. Maybe it's just the 7600GT's holding it back.
I have the 3D Fusion 7600GT and in 2nd PC below I get 3425; Clocked to 590/1580 it does 3652. So I'd say yours is fine.
T
NB: X2 3800 is @2.6GHz
T
My GPU is clocked higher than your even after you've clocked yours! Yet it's still slower with an identical spec....unless your CPU is clocked higher?
