Hey all, just installed a 3570K in my G/F's PC and she would like it running at 4.7ghz (she loves the number 7, don't ask, she's previously bought an XP 2700 over the 2800 and the ATi 4870 over the 4890 because of it lol). Anyway back on topic, the on chip GPU will be disabled in the bios which should help with temps, but how easy is it to get these to 4.7 and does it involve a lot of tweaking and fiddling with awkward settings? or is it just set multi to 47, set this vcore, reboot?
As far as cooling goes that "shouldn't" be an issue as her setup is water cooled and is currently getting good temps under Prime95 at stock clocks/volts, however before I try overclocking it the loop will be gaining an additional XSPC EX240 rad so that should be able to counter the extra heat from the overclock I would have thought.
