3570k cooling ?
15 Mar 2013
Hey guys and girls :)
Back again for some more help lol
So far I've got everything I need for my upgrads for my new system apart from one major component lol
CPU cooler!!!
was just siting here thinking i should start to put it together and forgot I didn't buy one!
Can any one recommend one what I won't have to replace 6 months down the line, also one that would stand up to a little over locking :)
got about £30 to spend I know it's not a lot but were in a recession; well my pocket is anyway. Or is it a big no no spending that amount on a fan and really spend a bit more ?
Ive got some Kingston HyperX Genesis Grey ram which is low profile so shouldn't get in the way of it, recommend by one of you guys.
Thanks guys
What's B grade? Is that people's returns, ie fitted to a machine then didn't like our broken them returned then fixed by OC's?
Posted from Overclockers.co.uk App for Android
It says at the top of the page.
Fully function, working items.. Missing accessories and no game vouchers or promotional items.
Items Something that was returned, opened, used for display, damaged box, etc. OcUK makes sure all the needed parts are included.
Thanks will take a look, so you guys think that's the best choice?
of hold out and spend a bit more
:confused:You said £30 and both Matterhorn and Havik 140 are £30.
Havik scores slightly better than Matterhorn on some review. Other say Matterhorn is better. Both are very good. As a B grade Havik may not have TIM so you will need some, Matterhorn comes with. You will need some alcohol to clean your CPU.
I didnt see the havik 140, its a good cooler ive got one on my 3770k till i finish getting my parts for water
