3570k core 0 temps?
19 Mar 2013
Hi guys,
Built my first pc over the weekend:
Zalman MS800 Plus Midi Tower Case
Gigabyte ATi Radeon HD 7950 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor
ASRock Z77 Extreme4 Intel Z77 (Socket 1155) DDR3 Motherboard
Corsair 2013 Edition Gamer Series GS 600W '80 Plus Bronze' Power Supply
Adata Premier Pro SP900 64GB 2.5" SATA 6Gb/s Solid State Hard Drive
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache
Corsair Vengeance Low Profile 8GB (2x4GB) DDR3
Prolimatech Megahalems Rev C CPU Cooler (With two Xigmatek Orange Line 120mm White LED Fans, the overclockers edition one)
Thread is here: http://forums.overclockers.co.uk/showthread.php?t=18498865
(Don't worry the fans are the right way round now... doh)
Anyways, I've been learning to overclock following the guides on here and online and was just wondering what core 0 is on speedfan? After running prime 95 for an hour or so all my temps are really low, but core 0 is up at 60 (I know that's not THAT high) with a little picture of a fire which I imagine isn't ideal?
Very much a newbie so interested in learning here.
Currently I'm 4.4ghz at 1.28v max (I want to try and get that slightly lower) and temps are all low while running it for a while other than core 0. However I haven't done a long 12 or 24 hour test yet.
Thanks for any help you can give me.
Also when I push it up to 4.5ghz, it wont boot into windows. What would be the next step? People are running 4.4 on lower voltage than me, so I thought it couldn't be that?
Thanks!
