I recently purchased a H100 refurb unit and a pair of Notua NF P12's to run a push pull setup, decided rather than go straight into overclocking I'd give it some time and just run it at 3.8Ghz for now. (400mhz from stock)
I tested it in prime for 2 hours and the hottest it got to was 53 degrees with it averaging about 51, now correct me if I am wrong but isn't this really low temperatures for a non delidded Ivy CPU?
If so do you guys thing this chip might be a good clocker?
Cheers
Ohh should note is a 3570K with a Gigabyte Z77 D3H
Cheers
