Hi all,
Building the wifes new PC, which is
ASUS P8Z77-V LX
I5 3570k
NH - U9B Premiumedition
8 GB Vengeance RAM
So I got it operational in windows and used the ASUS suite 2 to play around with some live action (change in windows) overclocking to see what I could get results wise.
So I found that at 1.15 volt in the CPU voltage, I could run @ 4.5 fine, I ran prime for 4 hours with no issues.
However the Asus suite wont let you make any changes made in the windows environment and keeps the Mobo defaulted *Turbo speeds* upon each reboot.
So I uninstall the application, and go to it the old fashioned way through BIOS.
Heres where things change, going into Bios setting Voltage to manual and 1.15 at 4.5 resulted in BSOD. I managed to get into windows on 1.2 but BSOD'd as soon as I ran Prime.
I set voltage back to offset and am now currently running Prime on a 4.0 fine and dandy.... Open hardware monitor tells me it's currently pulling 1.13 with a max of 1.84 temps are 60 or below (it's now hour two of testing).
Any idea of 1.) why I can't reproduce the test settings of asus suite through bios & 2.) any recommendations for the next steps? (I'd like to end up at somewhere between 4.2-4.5 below 80 on Prime)
Thanks,
James
ASUS P8Z77-V LX
I5 3570k
8 GB Vengeance RAM
Thanks,
James
