Hi guys, hoping for a little pointer or advice
I've recently looked into overclocking again, and I think I've settled at 4.2, for the most part it seems stable, however the only issue I've noticed so far is a game seems to frequently crash. Not even a heavy game, just Golf With Friends! the game itself is pretty poor and in early access, but its only started crashing since the overclock.
i also recall a few years ago when i attempted this overclock I had the exact same issue, except the game i played then was left for dead 2, however I ended up giving up and going back to stock
I'm fairly new to this so not sure what could be causing it, the only things I've tried so far is
1. Upping the vcore slightly, have it at 1.230v currently, tried up to 1.240v
2. Changing the VCCSA Voltage from auto(1.050v) to 1.100v, which I tried after a little google.
not sure if relevant, I've had to set the LLC to "Extreme/highest", as io cant seem to get it stable at anything less
the error log from the game:
spec:
3570k
Asus P8Z77-V LX
16Gb RAM 1333
not sure if i've included everything needed here, but does anyone have any pointers?
Thanks
Error occurred at 2016-12-25_200700.
H:\Steam\steamapps\common\Golf With Your Friends\Golf With Your Friends.exe, run by Carl.
21% memory in use.
0 MB physical memory [0 MB free].
0 MB paging file [0 MB free].
0 MB user address space [3212 MB free].
Read from location 00000000 caused an access violation.
21% memory in use.
3570k
Asus P8Z77-V LX
16Gb RAM 1333
Thanks
