3570K Stock Heatsink and fan
15 May 2012
Birmingham
Hey guys just wondering if you could tell me if getting between 26°c an 30°c is this normal on a stock heatsink and fan for the 3570k thanks :)
What are you measuring your temps with ?, that looks good for idle but what are your temps like running Intel burn test ?
Those temps are fine for idle but it is load temp you need. Download Prime 95 and leave it running for 15 mins then see what temps you get using Core Temp or Real Temp.
I would avoid Intel Burn Test as it cause the chip to heat up far more that prime 95.
hi guys i ran prime 95 for about 10 mins and after i checked temps and i got 60 to 61 to erm.... yeah new cooler needed when i have the cash thanks for all your help guys
