Deleted member 2277
Deleted member 2277
I'm not sure if this is a CPU issue or not but I'm having major issues with a new build and I was hoping someone could help me.
Started off with the following parts:-
Gigabyte Z77-D3H
Samsung green memory 16GB
Western digital drive 500GB
Antec 650w True Power
Intel 3570K Retail + Cooler
I assembled all parts and ran at stock speeds and installed windows 7 and drivers. During the driver installation I was getting 'explorer not responding' errors, various application errors and eventually a BSOD. I tried several windows installs but every one would end up the same.
I then replaced the motherboard with a MSI Z77A-GD65 (bios 10.7 and 10.8) and encountered the same issues.
I ran memtest 4.20 for 12 hours and this passed without any errors.
Thinking it could be a temperature related issue I replaced the retail fan with a Xigmatek Gaia CPU Cooler, I also replaced the drive with a SSD but still no good.
Tested with onboard video and a HD4850 same result.
Now this is where I am really confused, If I do a clean install of windows 7 64bit without installing anything else and run Prime 95 it will run fine (12 hour test) at full load temp of 50 degrees.
So the system seems stable until I start to install Windows SP1 or ANY drivers or software.
Other than trying another PSU I really don't know what else I can do.
Any suggestions would be greatly appreciated.
*** I've also tried Kingston memory.
Gigabyte Z77-D3H
