35bhp for $59.95 - Yes please!
Man of Honour
18 Oct 2002
UK
If you had $59.95 would you spend it on an extra 35bhp if you could? I would.
http://www.turbonator.com/
I've ordered 50, that should equate to an increase of 1750bhp. I'm going to pwn you all at the RR ;)
Seriously though, is there any truth in their claims? Doesn't that Ecotek valve gimmick thingy claim to do something similar?
Not if i buy 60 :p
Freefaller said:
Damn.... I feel I've been conned - I've just spent a decent chunk of change on high quality turbo equipment and now I find out I could have bought this? :(
Just think, for the money you spent on the turbo kit you could have bought about 50 of these, 1700+ bhp in an MX5 is a lot ;)
I just wonder how the hell they get away with the ludicrous claims.
So its a block of metal with fins attached to the inner sides.
So the only thing i think it could do is change the way airflow goes into the car?!
So a solid streem of air turned into a vortex of air?
Why?!
just brought 1, then i', going to copy it and make 100
The technology is sound, as to whether it works is another matter....
For many years tuners have argued about a smooth intake or a rough intake, the rough intake generates better air fuel mixing thru turbulence in the induction resulting in better power over the increased airflow of a smooth intake...
Adding something to create that turbulence in a smooth intake should yield good results in economy and performance...
You may take the mickey, but it may actually work... the technology is sound..
:cool:
:cool:
Yeah, but "The Turbonator is much less expensive and more efficient than any turbocharger, supercharger, blower, or intercooler. Its superior design increases horsepower while lowering fuel costs*".
I mean, come on!
I mean, come on!
Exactly - they haven't spent *years* developping and working with turbos and superchargers and other FI methods so that a piece of metal costing 60 bucks could outperform surely!! When they start using it in rally cars or other performance cars then I'll be convinced.
I mean, come on!
It is more efficient, it doesnt require anything to run it, generates no excess heat in the intake like a turbo/super and if it does what it says then the last part is sound...
Effectively it COULD give a degree of performance equivalent to having your engine ported with bolt on simplicity..
It has a money back guarantee why dont you try it?
No good for either of my cars... ones a turbo and the other has 4 throttle bodies..
:D
Freefaller, at least read the article, its stainless steel
:p
:cool:
Just need it to be rough eh?!
I'll whack a pc fan just before the air intake pipe, would that work too then?
Or could just put a piece of mesh in place.
You could probably make your own using a fan spinner... worth a try...
it wants to be solid tho to create a vortex...
:D
