35mm slides that can hold liquid
8 Jan 2004
I am trying to find a 35mm slide that can hold a small sample of liquid - something in the 0.3-1 ml range. I then want to put this slide into a slide scanner and get a picture of it.
Does anyone know where I can get my hands on anything like this?
I want a slide with two sides that come apart, and then I can use a dropper to put some liquid in the middle. I will then put the two sides back together and seal the liquid in the middle. I bought some stuff from ******** last week, but the plastic plates on each side leak, and there is no room in the middle so all the liquid gets forced out.
