360 Elite, Hdmi, And hard drive tranfers, and many other questions
29 Mar 2005
right i bought an elite today as i decided it was time to upgrade form my core + hdd. I got a jasper too which is all good :P so the questions i have are:
1:How long do you think ms will take to send me my transfer kit.
2:Im currently using VGA (at 1360x768), is it worth while for me to use hdmi instead, as this would out put in 720p which is a lower res than 768p obviously (is there a real difference) also
3: will using hdmi allow me to play original games that i couldnt before i.e LOTR ROTK
4:When i transfer my data will rockband songs etc be transfered too? is there anything non tranasferable?
5:do i need to do that thing on xbox.com with the licence tranfer or something?
6:finally what do i need to connect a hdmi to my tvs dvi input
thank yall in advance:P
1. Varies. Usually not very long.
2. If your monitor is 720p native, then set the 360 to 720p
3. You can play xbox games using vga or hdmi
4. everything gets transfered.
6. hdmi to dvi dongle
hey my tvs res is 1360x768
to 3. when i play some original xbox games, they get a pal 50 error i wondered if it would be adressed with hdmi
thanks order, so i guess that means one of hdmi's advantages is it allowxs me to play originals without cable swapping?
cheers this sounds stupid but does the elite come with a hdmi and component? i have opened the box yet and im not home lol
