hadnt we prooved they were a waste of money and that they did very little in providing better airflow for the 360 with the way the 360's layed out and where its fans are etc a fair while ago when they were first introduced?
Don't bother buying one,it will cause more problems than good.They take power direct from your 360 which can cause problems and they also cause burning to 360's power connector on the back of the console by arcing out due to the crap fit.The only mod i've done to mine is buy some AcoustiFeet pc case feet which raises the 360 height a bit and allows the base of the console to breath a bit better.
Yes they are supposed to be bad for your console as it piggy-backs on the power going to the 360 and can actually interrupt the supply going to the 360, which can equal the 3 rings of death.
Have a look on a well known internet store that does reviews and many many peeps are hopping mad as its killed their 360's.
