360 Not finding wirelss remote
have you pressed the white button on the console, then HELD DOWN the little white button (nearLB Button) on the controller to sync them?
Oliet_No1 said:
The white button on the console, as in the ring of lights or whatever its called?
Do i have to do that simultaneously?
No white button that is near Memory Slot B
1. Press that button (white button near mem unit b)
2. you should see the circular rings on the console flash
3. press and HOLD the little white button on controller near LB
4. after a few seconds they should link
5. voila
