360 pad and TDU - anyone had problems?
10 Dec 2004
Oxfordshire
TDU CRASHING - Not pad based....another game flaw (fix inside:))
Found the issue, its acutally the game, guy on the TDU forums is a total guru....made the save protector etc.
If your game startsd crashing on load screens and refuses to load properly
his solution to the issue is......
"load your game up as normal but once at your house instead of leaving the to play the game as you would normally, actually quit the game back to the desktop. Then load it a 2nd time and play as usual. Sounds strange but worked for me.."
Works a treat :D
Ta
Ben
