360 + vga + tft
11 Aug 2005
How exactly does this work ? Got my 360 today and a VGA cable, Im quite miffed my monitor doesnt have a audio input other than a 3.5mm jack so I can't get sound, but I just want the HD picture to work for now
TFT with a VGA connector, VGA Cable + 360 = no worky
Both the VGA connectors are female, thus, dont plug into each other, am i being really stupid or does this not work? How does everyone else connect their VGA cable to their VGA monitor?
cheers :) i am stupid!
now ive got an optical sound cable, or the sound connected to the vga (red and yellow composites)
is there any method of putting these into a 3.5 mill jack? is there an adaptor or do i need special speakers as well, because id sooner use the ones in my tft despite how poor they are
Mr Men said:
LOL again my cable came with a 3.5 jack :) check the box
checked, cant see one :( ! hoped i might have missed it in the madness i unpacked it in but still cant see it :( any idea where i could get one?
See the FAQ for help with your speakers. Look for the following question
Q: Help! I've got the VGA/Component cable connected to my TFT and I don't have any speakers! What can I do?
cheers
mr man, bought it as a bundle off ebay, so maybe he forgot about it as it was a core, and he had upgraded it:( will have to drop him an email, reason was i got it on buy now, for 120inc with GOW and HD VGA Cable :eek:
yeah worth a try emailing them see if they have it lying around, failing that prob find what you need at a local audio shop, wont cost much I dont think :)
Mr Men said:
My cable came with an adaptor to change female to male I am sure
yea so did mine
also any audio place will sell you an aux - 3.5mm connector thatl go into your monitor from the vga cable :)
an dive seen those female - female connectors in the MM on here before , think some gfx cards come with them , try the wanted section
Is it possible to get an adapter that allows a monitor to have 2 display adapters connected to it (Xbox & PC)? Sort of 2 VGA sockets to 1 VGA socket.
i hope so, so i dont have to keep switching my 360 and pc around, ill have to live with it for now tho as ive never seen one :o
I have a spare phono to 3.5mm plug... ;)
look for KVM switches, belkin do a good range of these :)
