360 What do i need?
27 Apr 2004
Doncaster, S.Yorks
Hey guys im a bit lost here, so im hoping you guys can help point me in the right direction at least, looking to get a 360 next week sometime, and im wanting to hook it upto my monitor, now it has a DVI and VGA connector no HDMI :( so im guessing i will be losing quality if i use the VGA.
Also how on earth will i connect my headphones to it? i dont use speakers at all just use my razer carcharias which have the normal 3.5mm jacks so any help on how i would do that would be appreciated.
I have mine plugged in by HDMI, I also use something like this I hope its ok to link that.
If your headset is better than 2.1, them im not too sure.
If you do go VGA, since it has male audio output, you may need some Female to female RCA adapter thingys. Something like this and this
Hope the links are ok.
You may need to get one of these for the mic so it fits into the controller. You will need to change the settings to that voice comes through the speakers.
Microsoft :). Whether or not it will annoy you, but i may be worth getting an extension on the 2.5mm one, it would personally annoy me having the converter thing near my hands.
