360 Wireless PC Connection
12 Mar 2006
Boarding the Nostromo
Hey,
Not sure if this is possible but my bedroom computer connects to the downstairs livebox using a wireless adapter. My 360 is also in my bedroom, i was wondering if i connected my 360 to my PC whether i would be able to connect to the internet??
I dont think this is going to be possible, but worth a shout!
Thx :)
It is possible, but will be too laggy for some games, so wouldnt bother.
Get yourself and wireless ethernet bridge or the 360 wifi adapter instead
Thermaltake said:
Hey,
Thx :)
It will work fine using ics. You will need a crossover ethernet cable though.
It will be fast as long as you're not downloaded loads on the pc at the same time.
Got it all sorted, very simple. Just ticked the Internet sharing box with the wireless adapter connection and finito! :p
