Hi, I've currently got a Gigibyte G-power pro cooling my xp 3200 and on the slowest speeds,1750 rpm, get temps of 34'c idle 42/3'c under load. In the next week I'm upgrading and getting a 3700 sd and wondered what the g-power would be like cooling that or would I be just as well using the stock cooler as I've seen that thats pretty good.
The side of my case is windowed so the g-power would look better but would rather have cooler temps as I intend to do some mild oc'ing.
Also how quiet is the stock cooler, just I used to run the g-power at about 2400 rpm and it blended into the sound of the other case fans but since I 7v modded 2 of my fans and replaced the others with akasa ambers the cooler had to be turned down cause it was clearly too load now it needs to be on its slowest setting to blend in with the other fans.
