17 Dec 2024 at 23:23 #1 atthegates atthegates Associate Joined 25 Jul 2014 Posts 86 Location Kerry, Ireland What load temps should I be looking at for this CPU and GPU and what should I set the GPU fan curve at? Last edited: 17 Dec 2024
18 Dec 2024 at 09:58 #2 mickyflinn mickyflinn Man of Honour Joined 23 Mar 2011 Posts 18,160 Location West Side Many factors are in play , CPU cooler type, GPU model ,case airflow ,fans ,etc
18 Dec 2024 at 10:44 #3 atthegates atthegates Associate OP Joined 25 Jul 2014 Posts 86 Location Kerry, Ireland CPU cooler is the amd one. Wraith I think it's called? Case airflow is not great. Two case fans. Zotac 4070 super twin edge oc edition gpu. mickyflinn said: Many factors are in play , CPU cooler type, GPU model ,case airflow ,fans ,etc Click to expand... Last edited: 18 Dec 2024
18 Dec 2024 at 11:09 #4 mickyflinn mickyflinn Man of Honour Joined 23 Mar 2011 Posts 18,160 Location West Side atthegates said: CPU cooler is the amd one. Wraith I think it's called? Case airflow is not great. Two case fans. Zotac 4070 super twin edge oc edition gpu. Click to expand... With the stock cooler anything from 65c to 85c and the zotac 4070 anything between 75 to 85c under load.
