- 22 May 2011
- Smoggyville
Hi guys
Pc has not had any love for a very long time, and I'm really behind the curve on how Ryzen auto clocks so I have a question...
The good news is, i dropped the 3700x into my current x370 mobo (asrock taichi) and after a bios update it seems to be stable - and i guess i should be thankful for this painless update since I'm sure there was plenty of scope for this to FUBAR
Now what I've noticed that half my cores are boosting all the time (they're taking shifts), even when I'm essentially idle, with all the cores managing to get up to at least 4.35 and mostly 4.4 - which sounds kinda sweet, EXCEPT that means it's auto voltage is between 1.45 to 1.49!! Wouldn't care if this was during a gaming hour but this is all the time and I didn't know if that was acceptable and whether i should be concerned, or is there anything i can do to limit the voltage? Temps are being reported in the mid 60s max and so under control (HWINFO64), idle can be a bit high compared to my old 1700 but its hard to judge when there are always cores boosting.
