My 3700X temps seem higher since I upgraded from a 1060 to 2070S. My case is the Lian Li TU150.
I have Noctua NH-U12S cooler, Noctua NF-S12A front intake and rear exhaust, 2 x NF-A12x15 intakes in the bottom of the case. My GPU temps seem ok, adding the two fans in the bottom helped lots as they are blowing at the GPU and assisting the fans, the problem is my CPU.
Idle temps right now in my cool front room, no heating on it's probably 18 C in here, CPU minimum 40 but it seems to go up and down between 50-55, when folding on CPU and GPU it will hit 83C I have seen it reach 85 C.
Should I worry about these temps? I think it's an air flow problem as with the case side panel removed the temps drop.
I like that the system is silent on idle, but I'm going to stop folding. In game the fans spin up and seem to keep everything fine.
