3700X Overclocking
6 Oct 2004
Southampton, UK
Hi
As you do when you are stuck at home and bored , I thought I have a little dabble at overclocking my system for the 1st time since I got it.
So I'm running a 3700X on a B450 Tomahawk Max using a X62 Kraken 280mm for cooling.
For starters I can get an all core 4.3Ghz using 1.325V set on the BIOS and can complete a Cinebench R20 run and getting almost 5100 core , compared to about 4900 on just standard PBO.
Temps look ok and hitting max of 75C.
Anyone else got the above combo and getting better results at all ? Not bad for a £90 motherboard.
4325Mhz will just crash running Cinebench R20 half way through , so its on 4300Mhz all core for now. Realbench 2.56 stress test stable after an hour. Had a quick go on the games and no crashing so far.
