3700x temps
3 Jul 2007
Rochdale/whitworth
ok iv just got a 3700x and at i have it OC to 4.3 all core and volts set to 1.26 but gos to 1.28 and im getting 73c hitting a max of 75c is that ok??
but when its idal the volts go to 1.33 ??? the idel temp is 34c
custom loop with the gpu on a 360 rad using aida 64 to stress it HW monitor for the temps
Seems a little high?
Can you run CB20 with multi core and use Ryzen Master to monitor temps? Only have one monitoring program open at any one time.
Based on your idle and load temps on that I can give you a comparison?
max of 67c on CB20 using Ryzen Master to monitor
what block, rad, fan and case?
its a Alphacool Eisblock XPX Aurora and a ek SE classic slim copper 360 and 3 CORSAIR LL120 RGB
To put some context, I got 71°C on the 3900X with the Noctua NH-D15 Chromax Black cooler, and 57°C with the 3600X, do you have room for more rad space?
its overclocked to 4.3 allcores plus its 8 core not 6 so what would you expect from it?
look at the power at idle and you'll see it is a lot less than when being stressed.
Your fans are a bit crap though and the rad isn't the best but your temps are fine just a little warmer than others may have.
I hit around 70c under a full all core load (which results in about 4.1ghz @ 1.4v with everything on auto) This is also under custom water with a 1080ti and 120x5 of radiator capability. So its a hot little chip.
yeah dose seam a hot chip fast but hot. Why dont you overclock yours to 4.1 then you will be able to lower the volts probable by a lot
