Deleted member 209350
Currently using a 2600 on a B450 MSI pro carbon AC motherboard. Its starting to show its age a bit so thinking of doing a mini CPU upgrade to hold me off until doing a full upgrade with either Zen4 or Zen5.
Will need it for some gaming (mainly play WZ atm) and also general work and stuff as well.
GPU is a 1070, and I have a 1440p 144hz monitor.
On the one hand I feel like I'll end up needing more cores because they get utilized a fair bit, but then the IPC gains of the 5600x make it so I might not need all the cores, as they are better - and most games seem to play better on the 5600x as well, however 3700x I can nab a little cheaper (probably £40 or so cheaper)
Thoughts?
Thoughts?
