3733Mhz low latency memory?
any of these would work i personally got the 2 sticks of 16gb 3200 cl 14 trident royals because they are b-die and overclock great. I havent had the chance yet to try it since my mobo is on preorder. A friend on mine with the exact same sticks but on intel got cl14 3800mhz if you are going ryzen im hoping to duplicate those speeds but at 3733 cl 14. One can only hope we can achieve some stupid tight timings for the expensive ram.
** This link is censored due to competitors **
You want screened Samsung B Die so 8 Pack and Certain G.Skill Trident kits are your best bet.
8 Pack 3866MHz would be a good shout should achieve C14 3600MHz with some tweaking.
Cheers guys. Memory reviews are few and far between today.
I got [email protected] teamgroup kit ill let You know whats the deal once i get cpu :) Got extra fan over ddrs ect been playing with them up to 1.5 volt so ill see what can get out of them. All depends what You want to spend... Paid for mine 240 or something like that now ram gotten cheaper. Deffo would like to have a go with 4266 8pack kit :)
Just about to purchase the 8 Pack 3866MHz C18 kit, would this be ideal for tuning at 3733MHz with 3900X & MEG ACE X570?
Also got this kit with the aim of going 3733 if achievable or 3600 with tight timings if not. Would be interested to see how you fare (or what settings @8 Pack would recommend on an x570, Taichi in my case)
I've not purchased but plan on doing so this weekend, let us know how you get on with tuning... 3600C14 would be nice if possible with this kit :cool:
I have my 3200cl14 8 pack kit on an x570 Taichi, r5 3600 and a Noctua DH15s, currently i can get:
3200 14-14-14-28 1.35v
3400 14-14 14-28 1.38v
3600 14-15-15-31 1.45v
3733 16-16-16 33 1.45v
now being a bit of an OC beginner and the differing opinions online i am currently sticking with it at 3400cl14 at 1.38v as i am not sure if running above 1.4v is goign to be detrimental (the RAM is advertised at 1.2-1.4v and when i input above 1.4 into my MOBO it changes to red text)
anyone better versed in OC than me care to advise if 1.45v is ok for day to day use or not? happy enough with what i have but would love to eek more performance out of it, that being said cinebench etc doesn't really seem to see much gains between 3200cl14 and the others posted above. 3600cl14 gets me about 30 point on average higher multi core (about 1%)
The minimum I would run is 3600MHz ram with the 3000 series for a minimum of 1800MHz FCLK. But then I speak from a 3700x perspective not sure if the same for the 3600 series.
You want to find what your max FCLK is before you find what your max ram frequency is. (Ram is double FCLK for 1:1 ratio)
