Morning gents (and ladies?),
I have been having a crack at overclocking my 3750k over the past week or so having done a large amount of research and reading.
I would like to be able to overclock at 4.4-5ghz using the dynamic vcore (& power saving options?) so that I can have reduced voltage's when idle, browsing the net etc.
This is where I have been encountering problems. My chip is stable at 4.3ghz with a voltage of 1.21v, ran Prime95 for 6hrs. When I change the voltage from the specified 1.21v to Normal and set up the Dynamic Vcore at 0.0v offset the voltage I get under load is really high, over 1.3v. To counteract this I went back into the bios and adjusted the offset and tested. At 4.3ghz the lowest stable offset I could use was -0.030v which under load gives me a voltage of 1.26v, higher that I'd like and I know the chip is stable at 1.21v. The main issue is that any further negative offset I introduce is causing the system to either freeze before boot or BSOD when idle. The negative offset doesn't seem to be getting enough voltage to the chip when not under load.
Any suggestions
Any suggestions
