3750k uneven temps?
27 Apr 2004
Doncaster, S.Yorks
Hey guys, got my 3570k upgrade on friday, and since then ive had a real odd issue with the temps being a little whacky, now its completely stock speeds as im unsure if the temps are safe to overclock in its current state.
Basically core 0 is 8-10 degrees cooler than 2,3,4 and i cant work it out, ive reseated my titan fenrir evo 4 times so far with no change in temps idle or load so i can rule that out i think but core 0/1 will not scale with other 3 evenly.
Example using coretemp and realtemp and ibt to stress.
Idle they are perfect
25/24/25/25
Load with IBT
50/59/60/59
Is this something i need to contact OcUK with on monday, or something i should be able to live with and just ignore?
I just popped core temp on and screen shotted it and as you can see mine is quite a bit of difference between core even at idle so I would say yours is normal.
Ok thank god for that, none of my previous chips have been so one sided before, they have all been been between 2 degrees of each other, so this was a little bit confusing, ill start ignoring core 1 and base it off the other 3 now, thanks guys :)
