375watts enough power for....
Suspended
23 Oct 2003
Cambridge
P4 660 (3.6ghz)
3gb ddr2
X850XT
2x250gb hdd's
SB X-Fi extreme
2xdvd drives 1rw 1r
or should i aquire a more powerfull PSU to power this pc?
i used the url in the first reply worked out my max load PSU useage would be 388watts, not good considering ive only got 375, guess im guna need a beefy'er PSU - Any ideas 60quid MAX for psu no 8000000watt quad sli compatible thing that i wont use guys :P TIA
You could get either a Seasonic or Antec 430w for ~£60 which will both be quite capable of powering your system, the Antec is modular as well so ought to be neater. A Hiper 580w modular is also around the same price. Do bear in mind though that your max load isn't often reached, however in your case it may be just as well to be safe.
yeh i dont fancy random lockups while gaming :) Which of the 2 is the most silent, this pc is proper low db i dont want to make it louder, cheers for the help as norm oc rules :D
I would probably say both are pretty quiet, get the Seasonic one, it's guaranteed not to let you down. :) Have one myself.
Is an old PSU without any seperate cable for cpu link of any use any more or is that essential even for web browsing etc?
I was refering to Socket A AMD ones and Ive done a bit of experimenting and found they do work even a mobile one but obviously the lead can help stabilise it but your most likely totally right about the newer more power hungry chips
