3770k bootlenecking a GTX 690
Get another 690. I just got the EVGA one which is working perfectly with the 3770 but you should get a swap rather than a credit note (as it's more expensive now)
I wouldn't consider a Titan at these prices especially for low res 1080p, unless you intend to get two which will blow the 690 away but at much greater cost £1660!
It could be a compatibility issue with my mobo who know? I'm a little weary about getting another one. If I were to get another one It would be a EVGA. I asked for a even swap, but he said if they find no issue with card he could only do a refund. It might be bull, but it doesn't matter. I'm either getting another 690 or a titan. Also you guys didn't take into account that I've been thinking about going high rez or multi screen and even if I didn't the titan is more then enough for me and whatever I decide to do. SLI just doesn't seem to work on my end. I checked all the settings and all seemed to working fine, but the 690 was just so damn slow???? like I said earlier it's probably just a faulty card and I shouldn't worry. Haven't had any issues on a single chip though. so a single GPU Chip could be the end of my issues.
