hey everyone,
think i'm posting this in the appropriate area.
I've gotten a strange problem, my ssd failed this weekend so i;ve done a fresh install on my secondary ssd. now th installation went off with no problems but when trying to do some final tweeks i've noticed an add issue...
if i have the power plan under windows set to balanced, then the cpu multi goes between 45x and 16x as expected as i have speed step enabled. if i then change to the high power plan and select the minimum processor state to 5%, like the balanced plan, then the multi steps....but also the bus speed drops below 100, e.g. 85, 66, 75. now i am 99.99999999% positive that it never used to do this prior to the new install.
some specs:
running i7 3770k @4.5 under a H80
asus z77 sabertooth
gtx680x2
16dg ddr3 1600 vengenance ram
the only things i know o have touched were the boot options as i was trying to see if i could fix the boot sector.
anyone had any issues like this before or know what it could be? could it just me a mis reading and it's just cpu-z being funny? i'm pretty sure with these generations you don;t want the bus speed going up and down to those extremes as isn't eveything linked to ir? cpu ram pci-e usb.... etc...etc...
so any ideas?
some specs:
asus z77 sabertooth
gtx680x2
so any ideas?
