Just to add to wazza's comment, a 3820 or 4820k would also suffice though the initial outlay of x79 can cost a bit more![]()
A 3 year old 700w OCZ ModXstream.
Fine for a single 780, but I wouldn't be happy running 2 on it with only 46A on the v12 rail.
but have you seen any benchmarks/tests regarding to i5/i7 comparison paired with the strongest cards (GTX 780Ti for example) in SLI ? What's the i5 impact result of lacking the HT capabilities in the accordance to the drivers overhead (especially in games that use CPU power so much, like BF4) ?
i5's simply run out of threads with dual cards on multi threaded engines such as frostbite and can in some cases create a bottleneck. I would always recommend an 8 thread i7 for multi cards these days
As for x79 x16/x16, the perf gap between it and x8/x8 over pci 3.0 has minimal impact, iirc in most cases its less then 1%. Going for a 3rd or 4th card then x79 all the way as most will do 16/8/8 minimum![]()
IMO More than 2 cards for GAMING is overkill, you will not get what you paid for
http://us.hardware.info/reviews/463...ay-sli-battlefield-3---1920x1080-+-frametimes
Benchmarks (3dmark) is another story..
from my own testing,
