I have been running my 3770K from 2012 - 2016 at 4.3GHz using the AISuite (I never really monitored the temps at the time as all was stable). Recently I uninstalled the suite and manually OC'd to 4.5 by changing the multiplier to x45 and voltage to 1.230v. Its stable but it is getting really hot, Idle temps are between 44-47 on all cores and just watching a 4K video on youtube temps hit 75-85 degrees C, sometimes one of the cores hits 91. I only started to really monitor temps after fan speeds started to spin up to 90% just to keep temps in control.
(while writing this my cpu clockspeed was 1600mhz and VID:0.9407, all cores were at 43-47 degrees)
I recently changed thermal paste from IC diamond which I applied in 2012 to thermal grizzly kryonaut which made little to no difference. I find this odd as I am using H100GTX with a custom fan curve via bios and speedstep is enabled. (Also have a 200mm intake fan with no obstruction, rest of specs in my sig)
The only method I've seen that would provide a noticeable difference is to delid (with Rockit tool) and apply liquid metal.
My questions are:
1. Is there anything I can do in the bios to reduce idle/load temps?
2. Is it worth deliding a CPU from 2012? (I am willing to do this) considering the fact that I have no intentions to upgrade my CPU/Mobo/Ram anytime soon, I would most likely upgrade my GPU one more time before looking to build a new PC as I am running it with a 4K monitor my gaming performance is 99% of the time GPU bound.
My questions are:
