Hi folks. Just moved to IB and Z77 and have sent last night and today getting used to the new UEFI and Asus software. At the moment I am running my CPU, an i7-3770K, at 4.4GHz at around 1.26v using Prime95 blend to stress it. All seems good at the moment with temps around 55 degrees but I have noticed at certain parts of the stress test, they shoot up to 67. Forgive me if I'm wrong, but I take it that when it does this, it a VERY intensive part of the test that probably won't reflect a real load situation? Also in regards to temps, I am using CoreTemp which is reporting around 50 degrees per core and I also have Asus TurboV EVO open and that is giving a CPU temp of 40 degrees. What do I go by, as at the moment I am believing CoreTemp.
) When it jumps its probably a small fft test, as they give higher temps.
